I tried electric starting a 1984 125 but nothing would happen. It wouldn't even try to start. What are some tips and figuring it out
Is the battery a known good battery? You can check the fuses, if good you can try putting 12 volts right to the starter to test it. If it cranks then you know it's wiring or switch trouble. If it doesn't crank the starter could need attention or replacement. The motor does turn over with the pull start, correct?
