Results 1 to 9 of 9
Thread: ATC250R case compatibility
    DDQ's Avatar
    DDQ is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2015
    Aberdeen, NC
    414
    I just busted my left 85 atc250r case. I am trying to find a pair to replace with and see on Babbitt's that the part numbers for the 85 cases are different than the numbers for the 86 cases. Are the 85 cases different than the 86 cases? If they are then no trx cases will work?
    Sent from my SM-G975U using Tapatalk
    6,728
    Slight casting differences and paint colors between the 85 and 86 cases but they are totally compatible with each other .
    They should be bought in matched sets but I’ve interchanged with no issues .
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    Slight casting differences and paint colors between the 85 and 86 cases but they are total compatible with each other .
    So for my 85 motor any year trx cases will work?
    6,728
    Yes the trx cases will work .
    Quote Originally Posted by DDQ View Post
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    Thanks!
    It looks like the only pairs on ebay have damaged left cases. Do you think this is repairable or should I not consider welding and wait until undamaged cases pop up?
    6,728
    Ouch !
    Their are guys that repair them , contact ESR , I’m sure he can steer you in the right direction .
    BarnBoy is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2015
    Oklahoma
    731
    There's a company out there machining billet 250r cases, I think the price tag is under a grand also. Which is actually not outrageous, considering what goes into something like that. Just an option....
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
    House Springs MO
    5,496
    Rob Selvy or Dave Moore on Facebook can repair those cases.
    Carthage NY 250r rules
    2,345
    X2 on Selvy or Dave Moore.Also check with BDT.
    250r rules
