Has anyone replaced the impossible to find integrated headlight switch on a '79 ATC 110 with a 3 position toggle switch?
Do you need it to be OEM correct? If you're not in a rush I modify Honda switches (the newer style everything else came with). It's slightly wider but you should be able to make room for it on the handle bar. Here's a pic. I also modify a Chinese switch, but it's nothing special, just trying to use up the stock and once it's gone I'm not buying any more due to them changing the design on me and making the appearance not as good.
The Honda ones are a bit on short supply, got 7 on back order. And I just about have them all account for people interested in them. So far all models I've made is $75 shipped in the usa, I might need some basic measurements and photos though, I don't think I have one on hand for the 79-80 atc110.
