Results 1 to 15 of 15
Thread: Swingarm Opinion?
    Dec 2019
    Long Island
    85
    Swingarm Opinion?
    So after heat, beat, chisel, repeat, I finally got what was left of my swingarm bearings out. This was all there was.Click image for larger version.
ID:	265231 Just the outer cage of the needle bearing . That's it. Nothing else was in there. Needles to say it was a bit over due. So now look at this. Click image for larger version.
Name:	inserted bearing.jpg
ID:	265232Do I need a new swing arm? I can drop the bearing right into one side. No pressure needed. It just falls in. I'm guessing a new swingarm is on order. Saw a fairly nice refurbished one for $325 on eBay. Is that my best bet or can this one be salvaged? I'd rather not have to shell out the $325 right before Christmas. Thanks for the input.
    In the garage
    2007 Yamaha Tri-Z 450
    2017 YZ 250F
    2003 XR100 (son's)
    2005 Raptor 350 (other son's)
    Gone but not forgotten
    86 350X
    16 WR 250R
    03 FZ1
    96 Katana 600
    89 XT350
    84 250R
    84 200X
    79 ATC 110
    74 ATC 90
    Dec 2019
    Long Island
    85
    Or does anyone know if an '85 swingarm will fit? I know they are different part numbers but anyone know the differences? It may be with the brake caliper mounts if I remember correctly. Thanks again everyone.
    In the garage
    2017 YZ 250F
    2003 XR100 (son's)
    86 350X
    16 WR 250R
    03 FZ1
    96 Katana 600
    89 XT350
    84 250R
    84 200X
    79 ATC 110
    74 ATC 90
    Feb 2019
    Western NY
    50
    Take it to a machine shop and have them bore and sleeve it. Take the bearing with you so they can measure it to get the fit correct. They should be able to line it up properly without too much hassle.
    1987 Honda 250SX
    1987 Honda 200X
    Oct 2020
    ME
    113
    could have some delrin bushings made.
    1980 Honda 110-125 lifan manual clutch *in progress*
    1985 200x - building peice by piece
    Manheim, PA
    5,759
    I always replace with delrin. Any machine shop can do it. Not a big deal
    Dec 2019
    Long Island
    85
    When you mention delrin what exactly is that? A sleeve inserted onto the bore with an inside diameter of the factory swingarm bore? That seems like it would be mighty thin between the swing arm bore and the bearing. There's probably only a 1/32 of an inch gap worn out.
    In the garage
    2017 YZ 250F
    2003 XR100 (son's)
    86 350X
    16 WR 250R
    03 FZ1
    96 Katana 600
    89 XT350
    84 250R
    84 200X
    79 ATC 110
    74 ATC 90
    Connecticut
    1,605
    What year and model ATC? Should be able to find a good used swing arm for way less than $325
    Manheim, PA
    5,759
    delring bushings replace all the sleeves and spacers and need bearings. Many people make them for models and sell on here or ebay.
    House Springs MO
    5,496
    What bike is this for? I make delrin bushings and can make them slightly oversized to compensate for wear.
    Dec 2019
    Long Island
    85
    86 350x. I have a machine shop putting in a sleeve and bushings. Thanks all.
    In the garage
    2017 YZ 250F
    2003 XR100 (son's)
    86 350X
    16 WR 250R
    03 FZ1
    96 Katana 600
    89 XT350
    84 250R
    84 200X
    79 ATC 110
    74 ATC 90
    House Springs MO
    5,496
    Quote Originally Posted by TSpencer View Post
    You probably could have found a new swingarm cheaper than the shop is probably charging. Unless it's a buddy doing a G Job.
    Dec 2019
    Long Island
    85
    Guy told me about $200. Cheapest swing arm I saw on eBay was $185 and looked pretty beat. Plus then there's the hassle of swapping out the axle, carrier, etc. For $15 more its worth it to me to be able to just bold the swinger back on, hook up the brake caliper and chain, bolt on the wheels and go. Should have it back today or tomorrow. Hope it works out.
    In the garage
    2017 YZ 250F
    2003 XR100 (son's)
    86 350X
    16 WR 250R
    03 FZ1
    96 Katana 600
    89 XT350
    84 250R
    84 200X
    79 ATC 110
    74 ATC 90
    Oct 2020
    ME
    113
    For future reference, having delrin bushings made would've only costed about 1/4 of what all that machine work did.
    If any of you guys ever need some bushings, adapters or collars made, I do small one off custom jobs for a reasonable cost all the time...
    House Springs MO
    5,496
    I would have made you a set of bushings for $35 shipped.
