Thread: 83’ Tri-moto 125 mikuni carb
    Nov 2017
    Fort Saskatchewan
    13
    Hey Everyone,
    Choke cable is seized on the carb. Lookin to just replace it with either a plunger or a new cable. Trouble finding parts for it. I think it’s a VM 22. Any help or suggestions would be great! Thank you.
    Not here
    4,728
    You might find a lever or pull knob style plunger here.
    I've also had luck taking the cable off and bending the outer casing around in tight bends with my hands for a minute to free it up. Also I'll soak them in transmission fluid, because that stuff creeps everywhere.
    Sometimes they aren't stuck bad, just stuck from sitting in one position for awhile
    https://www.jetsrus.com/carburetor/c...iew_parts.html
    Also try Sudco International
    That's where I get my oem mikuni parts
    eBay is a good source for aftermarket mikuni parts, but I always try to go with genuine mikuni or Keihin stuff to avoid problems
    Nov 2017
    Fort Saskatchewan
    13
    Thank you for the response. I appreciate it
    May 2020
    Antioch
    8
    My choke cable was seized sat for 20 years. I just sprayed some PBBlaster in there and worked the cable back and forth.
    The cable would only move 1/6 of and inch to start, but got to move more and more using a long needle nose and leverage on the fork tree. Took about a half hour. good luck, let us know how it goes.
    Nov 2017
    Fort Saskatchewan
    13
    Well I couldn’t free up the old one but I ordered a random one I found on Amazon and actually got it to work haha. Little short so I will have to mount it onto the plastics near gas cap. Also, had to file down the end to fit into the actual choke mechanism. Works great. Thanks for the help though.
    Onto the next problem. Bogging lots under load or with hard accelerating.
    Apr 2003
    Auburn, WA
    1,232
    Quote Originally Posted by benji_snod View Post
    What's the plug look like? Bogging under load is usually running lean. When's the last time the carb was cleaned?
    Hoarder of the finest junk
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '84 TRX200 trike conversion.
    '87 Tecate 4
    Lots of vintage and not so vintage two wheeled stuff.
    Nov 2017
    Fort Saskatchewan
    13
    I’ve been completely through the carb. And yeah that’s the same conclusion I came to. Also, it’s got no air box and just a cone shaped air filter so I upped the main jet size and it seemed to not help. Almost make it worse. It’s starts and idles like an absolute dream.
