Results 1 to 15 of 22
Thread: this is a parts trike.
    az
    1,949
    1st was a $60, 81 185s that was mostly all there, got it running new tires etc. next was a $40 92 185s parts bike that got put back together. I needed a spark advancer, front fender and forks so my parts guy sells me a almost complete frame for 50 bucks, has a stuck motor which now spins over. probably have it running this weekend.
    Now my latest pile of junk!
    85 200s, why did I buy it? its got a complete motor that spins fine, just no spark. found out its got a 83? big red rear axle assembly, busted big red rear plastics and probably a big red harness. (has a regulator). no front axle.
    I tried a 81 harness on the 200s motor and still no spark. Ill mess with it some more this weekend. Main reason I boight it, was for the bolts, switches, pull start, thumb throttle and carb, brake lever. Crazy thing, I had a axle and brake assembly for a 85 200s that I tossed awhile back. jim
    Attached Thumbnails Attached Thumbnails 20201229_160101.jpg   20201229_165204.jpg
    81 185s
    82 185s with 85 200s motor
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    projects coming along
    85 200s
    81 suspended 185s (can't believe I came across 2)
    1982? 185s
    Arkansas
    2,210
    Parts trikes are hard to come by even at those prices around here.
    Check out the mania on Ebay driving a lot of it. People posting ads that don't even know the year or model, and calling trikes original even though several parts have been replaced with aftermarket. I'm not sure who the bigger idiot is, the incompetent knobs posting the ads, or the people paying good money for pieces of junk.
    Keep on trucking.
    az
    1,949
    now that its dark out, went and did the spark plug test.....we have spark!. im thinking its got low compression, going to check the valves adjustment tomorrow. the headpipe isn't oily so I'm hoping it just sat. if the motor runs it give me options. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    az
    1,949
    intake valve was so tight it had zero play when cold. loosened it a bit and felt compression when pulling on the recoil. messed with a couple bad connectors and get intermitten spark I think its the black wire off the stator, need to put a real connector. ran a little gas down the carb and its wanting to pop. advanced the timing to the middle of the slot and it fired off once! going to advance the timing further tomorrow. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    Apr 2014
    Edmond, KS
    2,537
    Good to hear. You've been coming up with some pretty good deals lately.
    az
    1,949
    went and pulled the timing plug, timing was still off. moved the plate and started did run on the gas I squirted into the opening. The connectors seems loose and dirty, so thats the next project, then pull the motor, dismantle the frame and get this stuff organized. If the motor runs decent, its going into the latest 185 project. hopefully the carrier interchanges, the 185 carrier has rusty bearings packed full of fresh grease. going to try the 185 axle in theb200e carrier. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    az
    1,949
    went out and the motor started up. didn't blow smoke, carb probably needs to be cleaned. need to make room, so yanked the motor, its going into my other pile of junk project on another thread (found a broken intake manifold bolt). tossed the frame in into the side yard (it should go into the dumpster but....
    frame and forks check
    rear carrier and axle. check
    motor, carb, headpipe check
    harness, cdi, coil check
    hubs and rims check
    1 new tire and rim check
    handlebars, switches and throttle check
    gas tank. check
    110 or 185s rear fender to adapt.
    going to set the parts aside on the shelf. maybe at some later date, this one will get put back together. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    az
    1,949
    hopefully will be posting a pic of the next parts trike tomorrow. I need tires for my latest 185s, going to hopefully pick up a trike for just the tires and tank, but who knows, might be another project to put back together. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    az
    1,949
    just picked this up for parts. 85 125m. it had a pull start on the ad but went missing when I went to get it. But a 200s? pull start was included. motor does turn over no carb or intake. wrong tank and plastic but there is a good trunk lid. Not sure what the plastic fits, but I need the tank and wheels/tires for my 185s projects. ive got a 110 125m tank and a set of 110 plastics with brackets that fit
    almost a waste to strip it. not too bad for 65 bucks. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    BarnBoy is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2015
    Oklahoma
    731
    Lots of parts there for 75 bucks. I pick up any trike I can find under $100.
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
    az
    1,949
    The tank has surface rust in it. Dont see any rust bubbles so hopefully its a good tank. Found a intake and carb on my spare 125m motor, I might try to see if the motor runs. Too bad there's not a market for trike parts around here. Jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    az
    1,949
    this is getting stupid! hooked the wires up where they belong, the switch is busted so I pulled the contact apart, installed another 125m carb and intake, hooked a battery charger with the jump circuit. hit the start button and it spins and im getting spark. check the valve and the exhaust was tight. squirter some gas down the carb and it runs! carb needs a cleaning. tried to fill the bowl but it won't run with the gas in the bowl.
    Now to decide it its worth getting a few parts and keep it together. I have the correct tank and anolder 110 plastic which fits. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    patriot1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2020
    Palestine, AR
    356
    Jim: I will want to see your collection in a few months! You'll have a dirty dozen for sure! You can sell the 200m tank or trade it for. a. 125 tank for sure! The only other thing you will need. is a seat.
    az
    1,949
    I went and cleaned the carb this evening. hit the start button and it runs real smooth! No smoke! If I get time, I'll fix the valve stem and get 3 full tires. tape up any bare wires. and see how it shifts. If it shifts, might as well get a recoil next week if my buddy has a spare. order a key switch, clean the 125 tank and figure something for the seat. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    az
    1,949
    on the 125m, replaced the handlebar switch and jumped the broken key switch installed a spare throttle cable which was about a foot too long and a thumb throttle. it runs smooth, I rigged a gas bottle and sat on a towel and it seems to shift fine. The valve stems bad on 2 tires so the air goes out real quick. but I think it runs good enough to warrant a pull start. called my go to guy and he has one for 30 bucks. so no more jumping with a jump box. still don't know what to do with it. but it can go on the back burner. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
