Thread: Repairing stator wires
    Feb 2015
    Cairo NY
    53
    '79 atc110. The engine for the "scrap 110". What's an easy durable fix for the insulation of the wires where they exit the case rubber grommet? This is gonna be a rider, so durability and waterproofing are highest on the list. I dont care if it looks different than stock. Don't want to lose spark while splashing thru a puddle! The wires seem sound, but the insulation is cracked and the wires are exposed. Shrink wrap?
    Attached Thumbnails Attached Thumbnails 20210106_101134.jpg   20210106_101202.jpg
    BarnBoy is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2015
    Oklahoma
    731
    Shrink wrap and liquid electrical tape might do the trick for ya there.
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
    Aug 2016
    East of Worcester ma
    1,328
    Ive got these, i cant tell u if they'd fit. Two piece rubber the top fits firmly over the smaller case grommet. Probably need to un solder the wires though... to fit in (your) drilled holes but i suppose one hole then splice/slit the smaller gromet to get the wires in.
    No idea if it'd even work for you. (they are not drilled)
    One time offer for you of $10 bucks shipped if u want to try.?
ID:	265905 Click image for larger version.
ID:	265906 Click image for larger version.
    shep
    Feb 2015
    Cairo NY
    53
    Thanks barnboy & shep! I'm leaning toward unsoldering and replacing the wires, they seem more brittle along more of the wire than I initially thought. I have a couple extra stators with completely severed wires, I'll try those first. Not too many of these stators around it seems!
    Feb 2015
    Cairo NY
    53
    Not too bad soldering fresh wires in- got them to go thru the grommet too!
    Attached Thumbnails Attached Thumbnails 20210107_153702.jpg   20210107_163518.jpg
