I bought a 1985 350X completely disassembled in parts and boxes in the mid-90s .while I was riding my 86 350 x another X! rider said he had one completely disassembled for a rebuilt so now it's been sitting around for over 30 years and I'm about to rebuild the engine that was completely disassembled I looked up the crank bearings and the counter balance bearings and a seal to put the two case halves together and that's about $160 for bearings I figured I'd start with the engine at this point.
With the parts that I have collected over the years I think I have just about everything I need except some seals and gaskets like swing arm bearings axle bearings an axle shaft if anyone has an axle for the rear of a 350 x let me know. I'm pretty confident I can put the engine together I will send the head out in the cylinder out for that type of machine work but the lower end should be fairly simple with the manual in previous engine work that I have done. My 86 is completely polished and chrome swing arm and all that jazz that I rebuilt in 2000 with a brand new frame from Honda I did not reinforce the frame I just used the brand new frame straight out of the box for my build.
I spelled them contemplating I'm just putting together with no paint work and writing it as as is or I may completely blast and paint it upon assembly. [ATTACH=CONFIG]265973[/ATTACHED]
