Thread: ATC 70 Cam Chain tensioner help
    Sep 2012
    Indiana
    455
    The Honda manual makes no reference to the 2 types of tensioners used on this motor. I have the version to the right in the pic. The one on the left is an auto adjust, but it appears the one on the right is a manual adjuster. Anyone have any experience w/ this? How tight should the chain be, or do you just how to go by sound?
    6,725
    Loosen nut #25 and bolt #11 while the bike is in neutral and idling and it will self adjust , lock bolt #11 back down and then nut # 25 and your done . If the chain is still loose then it’s time for a new cam chain .
    Nov 2015
    Davenport iowa
    1,144
    Adjust by sound with trike running Loosen (25) back out slotted screw (11) tighten at the bottom until chain noise is gone
    1974 original 90 X 2
    1974 Original 70.
    Sep 2012
    Indiana
    455
    What about #12? This seems to also be an adjuster of some sort. There was some definite slack in the chain when I first removed the stator plate and started investigating the chain and tensioner. I put the tensioner back in, snugged #12 down, and all the slack is gone now. I'm afraid to just to tighten it as tight as I can go and then adjust #11 and #25 fasteners as mentioned.
