Results 1 to 3 of 3
Thread: ATC110 wheel spacers
    Feb 2015
    Cairo NY
    53
    Further progress on the scrap 110. It just seemed too narrow. So wheel spacers were checked into. Seems like they could be easily made, but the required aluminum isn't cheap! So the durablue spacers were found on ebay for about what raw aluminum could be had for. No brainer, right? Well, Not exactly a bolt on. The bolts holding together the 2 piece rims needed to have clearance cut into the spacers. The hubs and rims had to be drilled bigger for the included bolts. There were no nuts included with the spacers, and the bolts were too long, so spacers had to be made (for the spacers!!) But it still seems worth it, as the wheels are now properly spaced!
    I know I forgot to take the pictures with proper orientation!!
    Attached Thumbnails Attached Thumbnails 20210118_154034.jpg   20210118_154042.jpg   20210118_160620.jpg   20210118_162743.jpg   20210121_170505.jpg
    Nov 2015
    Davenport iowa
    1,144
    I would imagine those were for a 1 piece rim. On the split rim 3- bolt spacers they were a triangle shape that compensated for the rim bolts.
    1974 original 90 X 2
    1974 Original 70.
    Feb 2015
    Cairo NY
    53
    That makes sense. Hopefully that helps the next guy!
