Hello fellow riders!
I have a 1984 ytm 225 that I’ve been bringing back to life here and there. I’ve also been riding quite a bit lately and having a blast. However...
I am trying to change the centrifugal clutch, but I cannot get the clutch drum or clutch off the crankshaft. I’ve tried all methods I can think of so far and still can’t get it off (lined up the clutch basket so the centrifugal clutch would slide out, beat the mess out of the clutch drum with a dead blow and clawwhile applying pulling force, bent the clutch drum using a 3 jaw puller and broke the puller, did a small amount of prying but I didn’t like that very much so I stopped before it got nasty).
Only thing left I think of is applying heat to the clutch drum. I really don’t want to destroy the crankshaft just to address this clutch issue, but it’s getting really close to that. I’m assuming the splines must be twisted or otherwise distorted. Either that or I have to be doing something wrong because it is not supposed to be this hard to slide out the housing and inspect/replace as necessary.
Additionally, a yellow spring was laying in the bottom of the clutch cover when I pulled it. I’m assuming this spring goes to the clutch adjustment arm. Can anyone shed some light or maybe some similar experience? I can’t find any pictures or videos showing the inside of the clutch cover with the clutch adjuster setup. I can post any requested pictures that may help.
Thank you guys in advance for any assistance!
