Results 1 to 3 of 3
Thread: Big Red 250 centrifugal clutch puller ?
    Jun 2011
    SW Florida
    11
    The kick starter on this 250es slips and I am ready to change the one way in the centrifugal clutch. The manual says a puller is needed for centrifugal hub, is one necessary and what does it look like? Anything special?
    I googled the puller part # 07933-HB3000A . That comes up a threaded puller and the manual says use a two jaw puller?
    6,727
    I always try a light tap with a brass first , their only lightly pressed on , if that doesn’t work I use the correct 35mm puller .
    Jun 2011
    SW Florida
    11
ID:	266507Click image for larger version.
ID:	266506Click image for larger version.
ID:	266505Thanks short line, I have the parts and gasket so it went well. The centrifugal came off with a tap . The old one way had flat spots on the rollers, the matching surfaces i.d. and o.d. have some chatter marks I polished a bit with some 400 grit paper. Replaced the seals and buttoned it up the worst part was gasket removal.Click image for larger version.
    The kickstart works good now, but I notice the lever was well forward when the dots are lined up, the p o had it 4-5 splines rearward for longer kick, will it hurt to have the lever back for better kick stroke? Thanks
