That's usually a safe bet, most often white is white is white . . .
Jason
85 ATC 250R - restored stock other than 18" rears, nerf bars, Honda key switch, 14T front sprocket, and white tank and plastics (except rad shrouds)
87 ATC 200X - restored stock other than 18" rears and nerf bars
84 TRX 200 - rough but complete budget restore for wife and eventually daughters to bum around on
Eton Viper 50cc - oldest daughter's current ride
I got the rear fender off ebay flr 226 shipped. front was 75 shipped. jim
81 185s
82 185s with 85 200s motor
suspended 185s
85 atc70
1984 200s
85 350x 3rd owner
and a 72 ct70
projects coming along
85 200s
81 suspended 185s (can't believe I came across 2)
1982? 185s
seat cover and rear fender installed. front fender and decals will be here next week.
On the rear fender, the factory had nubs where the middle brace goes. the Maier doesn't have the nubs. I installed the brace but it doesn't do anything. is that correct? jim
81 185s
suspended 185s
85 atc70
1984 200s
85 350x 3rd owner
and a 72 ct70
85 200s
1982? 185s
picture of the new parts. jim
81 185s
suspended 185s
85 atc70
1984 200s
85 350x 3rd owner
and a 72 ct70
85 200s
1982? 185s
Looks awesome Jim!!!
Might depend on the seller, but both sets of Maier rear plastics that I've bought came with bolts/nuts/brackets to install on the fenders (drilling through the front side of the fender and leaving an exposed machine screw head) so you can use the factory brace. I didn't put them in the R fenders an have no intentions of putting them in the X fenders either. It would be nice to have the brace but their method of keeping it is just too clunky looking for me . . .
Jason
the fender has holes for the middle brace, im thinking of getting a rubber snubbed and bolting it to the brace so it just touches under the fender. jim
81 185s
suspended 185s
85 atc70
1984 200s
85 350x 3rd owner
and a 72 ct70
85 200s
1982? 185s
That could work, I hadn't thought of that . . .
I just knew I wasn't willing to do it their way, lol.
Jason
Trike is looking good with white. IDK about the 350X middle brace, but I leave them completely off the 250R's. Not needed IMHO.
The aftermarket plastic seem to match the '86 white. The white is different from '85 to '86 on the 350x gas tanks.
YAMAHA 450 HYBRID
85 350X- RED
85 350x -BLACK
86 350x-WHITE (with Goki)
85 250r
83 atc 70
84 atc 70
84 atc 110
09 yfz 450
2006 Arctic Cat Prowler
RZR XP 900
I haven't got out to the garage to verify yet but I'm not sure if that would work . . .
At least on the 200x and 250r plastic the brace "clips into" the inside of the plastic on each end and is anchored in the center by a couple half moon brackets. I would think that without the anchor on each end there wouldn't be anything to stop the brace from swiveling/swinging back and forth in those half moon brackets?
Jason
on the 350x there's a nub on each side of the plastic where the brace basically holds the end of the fender up. the brace is bolted in the middle. sort of like a 185s. jim
81 185s
suspended 185s
85 atc70
1984 200s
85 350x 3rd owner
and a 72 ct70
85 200s
1982? 185s
Yeah, I think we're talking about the same thing. The nub on each side of the factory fender kind of "hooks" onto each end of the brace, which allows the brace to to hold up each side of the fender, but also seems like it keeps the brace from pivoting/swinging (front to back) in those center brackets/hold downs? Not that they would swing free all the time but it seems like they could be jarred away from the fender when riding on anything but perfectly smooth terrain. Like I said though, I haven't gotten out to the garage yet to take a closer look, but it just seems like without any nubs to catch each end of the brace on the Maier fender, it might not stay in position and provide any support after hitting the first bump . . .
Jason
maybe bolting on a piece of 1x4 or 5 inch long piece of metal, put a rubber snubber on the ends, bend it so the bumper hits the fender in 2 places per side. Basically like a capitol T laying on its side. jim
81 185s
suspended 185s
85 atc70
1984 200s
85 350x 3rd owner
and a 72 ct70
85 200s
1982? 185s
