Results 1 to 15 of 18
Thread: maybe another trike project tomorrow.
    az
    1,949
    plan was to stick with the 185s projects because I have spare parts, but I'm checking out a different trike tomorrow, not sure it's a good deal, or even a good idea to get it. But if I do get it, I'll post pics and you all can laugh at my stupidity, maybe it'll turn into a long term project. maybe it'll be used as trading material.
    last post like this worked out with me trading for a 350x, this one is smaller. And basically a rolling frame. jim
    81 185s
    82 185s with 85 200s motor
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    projects coming along
    85 200s
    81 suspended 185s (can't believe I came across 2)
    1982? 185s
    wild200x is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2003
    196
    what is it? 200x?
    az
    1,949
    I wished, a little smaller. atc70
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    az
    1,949
    project atc70. some assembly required. but its a atc70. jom
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    Jul 2003
    196
    do you have the rest? Kind of good the motor is out as the backbone needs straightening.
    az
    1,949
    nope, that's all I got. but its a start. Actually I do have the foot pegs and the pull start. I've got a pit bike motor too. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    az
    1,949
    already got a response on my wanted ads. this 70 might end up running again. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    devore,ca
    1,015
    I agree that the frame is bent. Easy fix.
    I just sold a whole truck load of 70 parts 4 days ago. I could have really helped you out.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Jul 2003
    196
    Quote Originally Posted by BOB MARLIN View Post
    Yes, I just fixed one for a buddy a month ago. Jack and some heat.
    Arkansas
    2,210
    At least new, metal seat pans are available for the 70's.
    az
    1,949
    looking around ebay and on line, a person could probably put this back together with a new larger motor, new plastics, new seat assembly and a bubble tank for under 1000 bucks. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    az
    1,949
    bolted on a 50cc pit bike motor the other day, foot pegs bolted right to the China motor. found a twist throttle, and carb. ordered a pit bike electrics cdi, coil, plug etc. if I get some time, I'll get it wired and modify the flywheel so I can mount the pull start working then install the carb.
    I've advertised a parts wanted ad locally. I'm surprised nobody asked if the trike was for sale. maybe beauty really is in the eye of the beholder. With the prices I see for beater trikes, I'm surprised someone didn't want to try to build it. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    az
    1,949
    installed the harness, gave it a kick and got spark. then kicked it again and felt resistance. Found a broken knife blade under the flywheel. now there's no spark. I'm thinking something messed with the coils. So a new stator plate is on its way.
    I'm bad with long term projects and kicking around the idea of seeing if there's any sort of trades available. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    az
    1,949
    new stator plate showed up today, swapped it in and it sparked, a little gas and it runs. No idea what carb I have on there but probably needs to be cleaned. found a new china atc70 carb but the bolt pattern is too narrow. so going to switch back tomorrow after cleaning the pilot jet. but the motor did run a bit with gas down the carb. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    az
    1,949
    cleaned the carb and it runs and keeps running!. threw a new ad on craigslist to see if there's any cheap parts local.
    I was asked on my last ad if the trike was for sale, so I stuck a I don't want to sell it number on the ad. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
