Order new brake pads on motosport.com, they said they fit the rear. I put them on and the pad has to be too thick. The inside pad that's against the piston is all the way in, no problems there. But the outside pad is pressed all the way out but I can't get it on the rotor because of the gap between the outside pad and the bracket is too small. Have other 83-84 250r owners experienced this?
