Results 1 to 15 of 16
Thread: Looking at a 250sx for sale 2/26/21
    Nov 2020
    Pine barrens
    30
    I found our 2nd 3wheeler i think. Its an 85 (i think) 250sx. Its in pretty good shape and its all there... but it does have a blown rear. Im very familiar with honda rear diffs ( i have a fleet of honda 300s and most of my buddies have one too.) I'll take it apart and as long as the pinion gear is good ill rebuild it. I also have one on ebay im going to buy as soon as its on my trailer. Front fender has small cracks near shock, it has plastic tank, (hopefully he has metal one too, I can fix them) rear fender look complete. No rear rack that I seen. He said the pictures make it look better than it does when you're standing next to it but I think it looks great. He's asking $1250... ill let u guys know how it works out.
    Apr 2014
    Edmond, KS
    2,537
    I'll be waiting.....
    Nov 2020
    Pine barrens
    30
    Going today at 3. I dont have enough posts to add attachments yet on this forum yet or o would have posted the ones he texted me already....
    Cold Lake, Alberta, Canada
    3,001
    If it runs and isn't a total turd the price seems OK. Sounds like you have the resources and skills to fix the rest of the issues. Although it doesn't take long to make a 1K machine into a 2.5K machine if expensive parts are needed.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1977 ATC 90 w/83 110 motor (Fugly)
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    1978 Honda XL75
    Nov 2019
    Florida
    1,044
    250sx, best all round 3 wheeler ever.
    add a rack or not, its still a very fun and capable machine.
    Added a 200x front end and possibly a rear disc brake could make it perfect.
    MrC.
    mrc_builds on YouTube Channel
    My Addiction
    85 200m "Tallahassee"
    84 200x "SouthPort"
    84 200x "Van Halen"
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "The Money Pit"
    85 350x Code Red
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    Feb 2021
    NC
    10
    I love my 85 250sx, wouldn't trade it for anything!
    Nov 2020
    Pine barrens
    30
    We got it! I did end up giving him the whole $1200. It starts right up and runs good. Carb does leak a little, but we were going to run carb through the ultrasonic cleaner anyways. Were going to pull rear diff today and pray the gears are salvageable. I went on ebay to buy the used diff i found... and realized it was from a 250es... but also included in the description 250sx so I didn't order it yet. I want the tall gearing of the oem diff if I can find it. Im not sure how many posts I need add pictures but ill keep adding to this post to get my numbers up.
    Nov 2020
    Pine barrens
    30
    Here it is
    Nov 2020
    Pine barrens
    30
    Turns out rear diff ring and pinion gears are great. Its were axle splines and diff are wasted... so ring gear is part of that... going to try a better axle and that will probably get it going.
    Feb 2021
    NC
    10
    That SX looks good!
    Apr 2014
    Edmond, KS
    2,537
    I bought a 250ES that had the axle splines stripped at the ring gear. I didn't want to take a chance so I bought a used diff and axle. That's just a warning to be careful. You may end up buying another axle as well as a diff.
    Nov 2020
    Pine barrens
    30
    Well... I think I have a plan, this might turn into a cool custom build. A honda 300 fourtrax (utility style) is the same gear ratio as big red 250es so if im going to have to live with that ratio im gonna mate the fourtrax diff and axle onto the sx swingarm. The reason is the fourtrax whole rear-end is available piece by piece brand new for very reasonable prices. Ring and pinion set with bearings and seals for like $125, rear axle hub to hub with nuts $130. Plus I have a complete rear-end (my spare) laying around. Im searching for another swingarm to actually modify then swap in. Ill try to take lots of pics so I can post.
    Nov 2020
    Pine barrens
    30
    It will bolt on the swingarm and driveshaft should be just fine. Only have to deal with one side.
    Nov 2020
    Pine barrens
    30
    Honda 300 fourtrax rear end mated to honda 250sx. After I add some gussets I'll cap off and maybe shorten the original swing arm axle mount square tube. We went for a short ride Sunday night and it feels good. And like I said previously..... 100% of the parts are available for cheap. Now to figure out what size rear tire to put on to make up some of the lost gearing.
    Attached Thumbnails Attached Thumbnails 20210309_162334.jpg   20210309_162303.jpg   20210309_161836.jpg
    Nov 2020
    Pine barrens
    30
    Disc rear brake conversion in the works. I just have to wait for a rear caliper in the mail. I have the disc,hub and mounting material just need some dimensions.
