Yes, probably the best idea. Will plan to just take it off and clean her up then.
Ok thank you. Will try stating with that and see how she runs after cleaning the carb.
100% agree on rebuilding the carb. I’ve had many Chinese carbs and never had good luck. If you go carb route a Shindy rebuild kit is the way to go. Keep the OEM
