Thread: Big Red 250 Inhibitor Switch Fix
    Mar 2021
    Mapleton
    3
    Cool Big Red 250 Inhibitor Switch Fix
    I have been reading through any posts I can get my hands on to figure out a way to bypass or fix my inhibitor switch on my rebuilt Big Red 250. Local Honda shop diagnosed it at the inhibitor switch and from what I have read I would agree. Any help would be appreciated!
    6,726
    If your talking about the neutral safety switch ? It’s on the right side of the motor , pull it off the sensor and ground it , neutral green light should come on now .
    Mar 2021
    Mapleton
    3
    Hi shortline10. Thanks for the quick reply. i have neutral green light. I am not getting any spark. It was intermittent, then went completely flat.
    6,726
    If your green light turns on and off with the gear selector then your inhibitor / neutral switch is working properly .
    I can tell you the most faulty ignition parts on that machine are the ignition switch and the CDI box .
    The switch can be easily tested with a multimeter but the CDI can only be tested against a known good working one .
    Make sure to check all electrical connections to rule those out .
    Mar 2021
    Mapleton
    3
    Will do. Good advice. Will let you know what I find out. Thanks!
