Results 1 to 15 of 19
Thread: ATC 350x rear master
    devore,ca
    1,015
    This has been gone over many times but I still don't see something that we all agree works.
    Has anyone found a good fitting and functioning replacement for the 350x rear master ?. I've been using the master from a 250r for years but now they are scarce. I'd like to hear from some of you that have successfully used something from a more modern bike or quad. I found on of a Yamaha dirt bike that looks close but it hits the exhaust.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Manheim, PA
    5,754
    2006-2009 KAWASAKI ninja 650R, bolts right up. you need to drill out the tapped holes in the cylinder for thru holes and add a washer behind each tab. That's all. I just put one on mine. $11.00 shipped lol
    Connecticut
    1,605
    Got a pic of it installed to share?
    I've always just bought anything Japan made that's close and made a bracket.
    The YZF seemed to work fine by just opening up one hole.
    I'd have to search for the proper year but I'm running one of those on one 350X and some random model on another.
    Manheim, PA
    5,754
    Yes. Just drill out for m8 thru hole add a washer and go about your day.
    Attached Thumbnails Attached Thumbnails 20210327_185412.jpg   20210327_185428.jpg
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,237
    late model yz450 works perfect, it doesnt get in the way of anything and has its own rezz,,,, Click image for larger version.
    Manheim, PA
    5,754
    Looks like its in the way of the exhaust bolt or just an illusion?
    devore,ca
    1,015
    Hey KASEY, long time !
    When you say late model are you saying aluminum framed ?. I looked at the master that's on my wr450 and it looks like it might bolt up, have you tried any of those ?.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
    Feb 2017
    Arkansas
    529
    Are the bolts coming through the back side?
    KASEY's Avatar
    4,237
    No its far enough away ,
    KASEY's Avatar
    4,237
    it has studs in the master the 6mm nuts fit in behind the original mounts , no drilling or removing the original threads either.
    KASEY's Avatar
    4,237
    Quote Originally Posted by BOB MARLIN View Post
    yes 06 or newer master, perfect fit.
    Feb 2017
    Arkansas
    529
    Thanks Kasey....makes sense
    I saw you post this several years ago and made a note of one of these fitting but could not picture what you did to attach it.
    Also made note you used an XR400 headpipe on a 350X......I think that was you????
    KASEY's Avatar
    4,237
    Quote Originally Posted by arky-x View Post
    thanks kasey....makes sense
    i saw you post this several years ago and made a note of one of these fitting but could not picture what you did to attach it.
    Also made note you used an xr400 headpipe on a 350x......i think that was you????
    yes you are right
    KASEY's Avatar
    4,237
    Better pice together
