Thread: 250SX Top End Rebuild
    Feb 2005
    Canada
    663
    Just curious how involved it is to replace the rings on a 250sx?
    I want to take apart as little as possible. if I just want to change the rings and I buy a top end gasket kit and set of rings will that be all I need?
    I'm assuming I need to take the head off as well to get to the piston.
    What's the simplest way to do this. First time doing a 4 stroke.
    1984 Honda 250R
    1985 ATC 250SX
    1985 Tri-Z 250
    1983 Honda 250R
    1986 Honda 350X
    1983 Yamaha Tri-Moto 175
    1983 Honda Big Red 200
    1981 Honda ATC 110
    Apr 2014
    Edmond, KS
    2,534
    It sounds like you're on the right track. I hope you realize that you will have to take the engine off of the frame in order to do a top end. Why are you just replacing the rings? Do you know that the piston is in good shape? How about the cylinder bore?
    Feb 2005
    Canada
    663
    Oh really, I guess I'll scrap that idea for now. Compression is still 150 so I can live with that for now I guess. Thanks
    1984 Honda 250R
    1985 ATC 250SX
    1985 Tri-Z 250
    1983 Honda 250R
    1986 Honda 350X
    1981 Honda ATC 110
    6,727
    The Cylinder head comes off without removing the motor , it’s a little tight but definitely doable , I have rebuilt hundreds of these over the years .
    Feb 2005
    Canada
    663
    So I would have to take the head off, then the cylinder and the motor could stay in?
    Would I only need the top end gasket kit and rings to do the job?
    1984 Honda 250R
    1985 ATC 250SX
    1985 Tri-Z 250
    1983 Honda 250R
    1986 Honda 350X
    1981 Honda ATC 110
    patriot1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2020
    Palestine, AR
    356
    I am working on the top end of one now on a SX. It's tight but you don't have to pull the engine. Spent more time trying to get the exhaust apart than anything else. Piston, rings and cylinder installed today but if I had 150 psi, Id leave it alone.
