Various 3 wheeler parts
Located in Massachusetts, can ship. Not sure what to ask for any of it, but I can send pictures and figure out a price. If you're local I'd be willing to trade for some welding work on a mini bike I'm building and the headlight cage on my 200es
ATC 200m front shocks- Sold
ATC 200m tank- pretty good shape, no petcock or gas cap, slight surface rust inside but mostly clean metal, couple dents, paint isn't great but no awful either
ATC gas cap- Sold
ATC 200es forks- not sure if they're useful for anything but just throwing them out there, they have some play forward and back, do not move very freely, crappy rattlecan paint job on the top part
ATC 200es axle/wheel hub/brake- paint isn't great but functional and perfectly usable, only issue is the studs were replaced with bolts at some point
ATC 200es headlight cage- very nice shape, a little flat black overspray but not bad, paint is pretty good, no dents, cracks, or any damage worth mentioning
ATC 200x rear wheel hubs- very nice shape, paint isn't the best and very slight surface rust from sitting around for years. Bolt on and go
200es front rack with supports- Sold!
200es front fenders- both have usual scratches from use, one has a mudgurad but has a crack in the leading edge, other one has no mudguard but no cracks
200es trunk- may fit others, no major damage, dirty and rubber strap to hold it shut is snapped
200e motor- patrially stripped down, missing parts but has compression, good parts engine
Kawasaki KLT 160 forks- no triple tree top bracket, missing the bolts to clamp around the shocks, crappy brush paint job, otherwise looks pretty usable and nice, shocks work as they should, can include axle/ hub/ rim with tire, those parts may or may not be usable, I'm not sure
//ArrowChat Integreation Code
