85 250r Voltage Regulator Rubber Mount
When my buddy and I put my R together it was missing the rubber mount so we improvised by bending the frame tab so it pointed down, drilled a hole matching the hole in the regulator, and bolted it on. Well, checking it over yesterday I discovered that I lost the bolt/nut sometime last summer. So I decided to look into getting one of the rubber mounts before just replacing the bolt/nut.
There are a couple on Ebay for around $30, which isn't terrible, but I wanted to check here to see if anyone re-pops them or has one kicking around?
The Honda part number is 30406-HA2-000
Thanks all.
Jason
