Results 1 to 7 of 7
Thread: Before I do the whole top end
    Mar 2009
    new england
    1,391
    Looking for my source of smoke
    1) fresh gas not mixed
    2) pulled exhaust packing
    3) compression test gets me to 160s at about 8 kicks throttle open (cold or warm)
    4) leak down at tdc at 100 psi shows maybe 4-5 psi leak or less, can’t hear a leak
    Starts on first kick, runs great more smoke on throttle, minimal at idle
    KISS is rings but I’m not able to prove it
    Aug 2016
    East of Worcester ma
    1,328
    One 86 200x i bought yrs ago now, seller had recently switched over to synthetic oil and claimed it smoked due to that ya sure.....whatever u say. well i bought at a decent (cheap) price at the time. Funny thing is after two dino oil changes the smoke stopped and has run great ever since. Maybe worth an oil change or two, i wouldn't have believed it myself but i saw the smoke clear up after a few days. I have stayed away from synthetic oils in my bikes ever since.
    just my experience..... on that one particular bike.
    otherwise valve seals are cheap, you must have a borescope around that shop somewhere to peak inside the cylinder through the plug hole.
    good luck, you'll like that bike when u get it running good..
    shep
    Mar 2009
    new england
    1,391
    Rechecking my leak down
    I may not have swapped out hose w valve on it
    Apr 2014
    Edmond, KS
    2,535
    I'll have to agree with Shep. With that kind of compression, I don't think that it's in your rings. I would lean toward valve seals.
    Nov 2019
    Florida
    1,044
    Try the oil change, but I bet the valve stem seals are leaking.
    mrc_builds on YouTube Channel
    My Addiction
    85 200m "Tallahassee"
    84 200x "SouthPort"
    84 200x "Van Halen"
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "The Money Pit"
    85 350x Code Red
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    Connecticut
    1,605
    Like Shep said try fresh oil. My 86 200X smoked when I bought it, oil looked milky almost like it had some water in it. Fresh oil and all smoke disappeared after 10 minutes of riding. No smoke since and bought it back in 2013
    Scootertrash's Avatar
    In the sticks
    4,628
    Another vote for valve guide seals, try an oil change first.
