Results 1 to 15 of 57
Thread: 84 and 85 200M
    DDQ's Avatar
    DDQ is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2015
    Aberdeen, NC
    414
    84 and 85 200M
    Hello. I have just acquired an 84 and 85 200M. They have sat in a conex box for many years. The owner has had them both for a very long time and gave me great details on them both. He said both smoked when he pulled the motors and I can see scars on the pistons. He said the 85 has slight play in the crank rod and that I should not run it like that. He says the 84 has a trans that is neutral at the top and the 85 is neutral at the bottom.
    I dont mind doing a case split but I'd rather not if necessary and my plan is to make one rider out of the two.
    My questions are:
    Is there any reason I should spit the cases on the 85 motor and replace the crank in addition to replacing the top end? My current plan is to simply replace the top end on the 84 and pit it in the 85 chassis. Also, other than the trans being different, are all other motor parts interchangeable between the 84 and 85? Thanks!
    Sent from my SM-G975U using Tapatalk
    6,727
    Check the cranks for any up and down play , side to side play is ok . Any up and down play and the rod will need replaced .
    Parts should all interchange .
    Honda changed to the up shift in 1985 so children couldn’t jump on the machine while running and easily shift it by standing on the shifter , dangerous.
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    Interesting fact!! Thanks
    Arkansas
    2,210
    Any idea what the black stenciled letters and numbers on the fuel tank are from? A motorpool? The air pressure decal seems like a motorpool thing too.
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    I don't know but I can ask the seller. What is a motorpool?
    Apr 2014
    Edmond, KS
    2,537
    A motorpool is where they fix vehicles in the military.
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    I want to go ahead and order a piston so I can take it to a machine shop with a cylinder for boring. Both cylinder bores measure between 64 and 65mm. Does that mean both cylinders are on the original bore and is the first step up to a 65mm piston?
    6,727
    Std bore on a 185cc motor is 63mm and a std bore on a 200cc is 65mm
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    kiser's Avatar
    Coshocton Ohio
    525
    Lol that's a brutally honest and funny sticker!
    Arkansas
    2,210
    From the decal, trikes were the last hurrah for natural selection.
    That makes sense why the guberment had to intervene. Can't have the useful idiots killing themselves off.
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    I have started tearing down the 85 and I dropped off the cylinder at a machine shop for boring.
    BarnBoy is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2015
    Oklahoma
    731
    I have a 84 200M build thread and pictures of the engine build etc. Go check it out, May be some useful info for you. I also have a fork rebuild writeup when that time comes.
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    Quote Originally Posted by BarnBoy View Post
    I found your fork rebuild thread but can't find the 200m build thread. Can you post the link?
    Thanks!
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    I've got the 85 stripped down as far as I'm going to take it. I'm going to wire brush/wire wheel on a drill the frame and paint it black. It's pretty pitted around the rear.
