Results 1 to 9 of 9
Thread: cheap 200s brake shoes?
    az
    1,949
    went to install the rear brakes this afternoon. old shoes had no lining left, new shoes popped in but the drum won't fit. double check the shoes, identical to the old shoes. drum fits without the shoes.
    I've got the adjustment to the shoes are as close together as possible. going to hit the flat spot where the eccentric spreads the shoes with a flapper disc tomorrow to get the shoes to close a little bit more.
    anyone ever have this issue? jim
    81 185s
    82 185s with 85 200s motor
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    projects coming along
    85 200s
    81 suspended 185s (can't believe I came across 2)
    1982? 185s
    6,727
    The casting on the cheap China shoes suck , I only use them as a last resort if nothing else is available . Sometimes you can grind / cam side of the shoe to make them fit .
    Stopping usually sucks as well .
    az
    1,949
    any recommendations for decent brake shoes? jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    Aug 2006
    new hampshire
    914
    I bought a set of ebc shoes and had the same issue. Buy a used set of Oem if you can find some
    1982 ATC 70
    1983 ATC 200E yard rat
    1984 ATC 200X
    1984 ATC 200S (X2)
    1985 ATC 70 (X2)
    1985 ATC 200S
    1985 ATC 250R
    1986 TRX 70
    1986 ATC 350X
    2004 kfx 700 XC
    2006 prarie 700 XC
    2009 Brute Force 750
    2020 CF Moto 600
    Aug 2006
    new hampshire
    914
    Maybe try to have the drums machined And cleaned up
    1982 ATC 70
    1984 ATC 200X
    1984 ATC 200S (X2)
    1985 ATC 70 (X2)
    1985 ATC 200S
    1985 ATC 250R
    1986 TRX 70
    1986 ATC 350X
    2004 kfx 700 XC
    2006 prarie 700 XC
    2020 CF Moto 600
    6,727
    OEM if available is the first choice .
    EBC , veserha , SOK are all good shoes as well .
    Nov 2019
    Florida
    1,044
    Hey Jim is your drum clean? I have had some that had enough surface rust/pitting to keep the drum from sliding on over the shoes.
    I was able to use a dremal with a sanding wheel, with the machine running on jackstands, and use it like a lathe, basically resurfacing the drum (cleaning it up) and then it fit fine.
    Its last resort kinda thing but it worked.
    MrC.
    mrc_builds on YouTube Channel
    My Addiction
    85 200m "Tallahassee"
    84 200x "SouthPort"
    84 200x "Van Halen"
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "The Money Pit"
    85 350x Code Red
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    az
    1,949
    the drums clean, I think the shoe is just a little too thick. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    az
    1,949
    took a little off the flat shoe and it slipped right on. adjusted the foot and hand brakes. all is good.
    went and bought a Walmart yoga pad to build up the old seat foam, got a 24.99 seat cover off ebay. while the cover works. it's nothing like the hi flite kit I bought for my 185s. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
