Thread: 1986 200x carb help please
    Jun 2009
    Tunkhannock,Pa
    904
    I did a full rebuild on the stock carb had it dip cleaned. Which means I removed the pilot screw and yes I know count how many turns when taking it out well I didn't do that. My mistake So I need to know how many turns in to the stock position. The manual says 2 turns out from a lightly seated position but can't seem to figure that out. I really appreciate any help Thanks
    Sent from my moto z4 using Tapatalk
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    Jun 2009
    Tunkhannock,Pa
    904
    Quote Originally Posted by RodKnockRacing View Post
    Also it runs with a cheap repop carb with keihin jets. Just trying to get the stock carb figured out
    1985 200X
    66mm H&S Piston
    Bassani Exhaust
    6,727
    Tune that screw for the best smooth steady idle , if it has the correct size small jet it should be anywhere from 1-3 turns out . The factory setting is just a starting point .
    Jun 2009
    Tunkhannock,Pa
    904
    Thanks Mike
    1985 200X
    66mm H&S Piston
    Bassani Exhaust
