Brake clean is fine for that, i have used diesel fuel in a spray bottle in a pinch, just rinse it all out, tip it left and right and make sure its all drained out, run it with some fresh oil for a while then do another change to clear out anything that loosened up but didn't come out with the cleaning.
For installing the oil rotor what i use is a chain vise grip around the centrifugal clutch, but a strap wrench works, or even a ratchet strap around it to give some grip, those bolts don't get torqued that tight, i think its something like 7-9 ft lbs. So its not like super caveman tight on those they will snap off pretty easy if your not careful cause they are only m6 bolts.
1984 Honda ATC200ES "Big Red"
1982 ATC200E "Hondie"
