Thread: Atc 125 battery shorting
    Jul 2020
    Montana, USA
    119
    Hi. I recently got a battery for my 125m. When I hook it up, everything is fine, neutral light turns on. When I push start though, the pos terminal sparks and light turns off. Any thoughts on cause.
    Connecticut
    1,605
    loose connection or corrosion at the battery cable
    jasong_10's Avatar
    jasong_10 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2020
    Croghan, New York
    420
    Quote Originally Posted by sledcrazyinCT View Post
    Ditto, ran into this when I went through the father-in-law's Fat Cat. Cleaned up the battery terminals and made sure the cables were good and tight, been good ever since.
    Jason
    85 ATC 250R - restored stock other than 18" rears, nerf bars, Honda key switch, 14T front sprocket, and white tank and plastics (except rad shrouds)
    87 ATC 200X - restored stock other than 18" rears and nerf bars
    84 TRX 200 - rough but complete budget restore for wife and eventually daughters to bum around on
    Eton Viper 50cc - oldest daughter's current ride
    Scootertrash's Avatar
    In the sticks
    4,628
    I typically clean ALL the connections, especially the ground connections, on these old machines. Do it once/do it right the first time, and you should be good for years!
