'83 ATC 185s rear axle snap ring
I'm in the process restoring a 185s to something similar to what I had as a kid, basically stripped down, front fenders, chain case, mud flaps gone. But I ran into a situation with the rear axle/sprocket. To get the rear sprocket off I needed to remove a huge snap ring. I destroyed it in the process. My question is do I need to use it?
On my '82 I had as a kid the sprocket had an internal damping system. When you changed to a conventional sprocket you did away with the dampers. On the '83 there are 4 bolts mounted in rubber, I'm afraid that without the snap ring the rubber holding the sprocket with flex and throw it out of alignment during acceleration.
It is necessary. You can find them on Ebay it is 42mm circlip that is used on a few hondas.
//ArrowChat Integreation Code
