Results 16 to 30 of 37
Thread: tell me about suspended 185s'???
    az
    1,949
    I'm in tucson arizona, we only get rain 2 times a year. jim
    81 185s
    82 185s with 85 200s motor
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    projects coming along
    85 200s
    1982? 185s
    Mar 2020
    Palestine, AR
    356
    Good score Jim!
    az
    1,949
    wasn't sure if it took a stock length chain so ordered 2 chains, air filter and a spark plug. if I can find a little time, I'll have it mobile in a short time. the hubs I ordered for the 200x project showed up, probably install them and the new tires on the back of this thing since the rear tires are cracking. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    2,208
    Quote Originally Posted by Jim mac View Post
    Yeah, but you get a year's worth of rain those two days.
    Rivers go from a walkable dirt path to flooded in an hour.
    az
    1,949
    parts arrived, took 2 links out of the chain to make it fit, the tensioner works fine on the bottom of the chain but the top of the chain comes close to the pivot point. got a bolt on air filter on it now. I can fill the carb with a tube and bottle and it starts right up, no smoke! next up install the tank and see I I can find fender brackets for the rear fender in my box of junk. Then try to figure out what to do about a seat. atcheaven shows the 185s pans in stock but I can't find a good way to attach foam or covers on it. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    Jun 2003
    South of Rochester, NY
    3,470
    Cool. I picked up a full suspension 185S last month. Mine is a 1983. Cool story on it. Guy ordered it from Honda end of 82, and before he picked it up had THEM install the PK rear suspension kit and a set of Gateway Wooly Boggers on the back. Still there! Click image for larger version.
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    az
    1,949
    put the fenders and seat off my other 185s onto the suspended trike, China carb, found a hole in the original tank, so put a 200s tank on it, installed a air cleaner and chain and it runs great!. I picked up a pair of 200x hubs, going to swap the rear wheels and tires with a pair of dwc wheels and new rubber sitting in the shed. Talked to a guy that might have a extra seat pan for the 185s to compete this thing. jom
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    ZacH_GrifF's Avatar
    ZacH_GrifF is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2011
    Pearl, MS
    405
    I have a whole build thread on my home made suspended 185s if you care to look through it. I tried to use as many factory oem parts as I could. Not finished making it pretty but its officially a bike i can take anywhere and beat on it without issues.
    http://www.3wheelerworld.com/showthr...n)-2021-Update
    1. 83 185s: (the money pit) xr200 cam, 200cc cylinder, 10.25:1 piston, 83 250r front end, 450r hubs, full suspension
    2. 85 Big Red 250es: in pieces
    3. 85 200m
    4. 00 Polaris Magnum 325 2x4: stays broke
    5. 02 Yamaha Wolverine 350 4x4: trail bike
    az
    1,949
    looks great, and a lot of work!.
    here's a pic of the rear suspension on my latest 185s suspended trike. all these years I've been messing with trikes, I've never had a suspended 185s and in a month I end up with 2. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    207wheelin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2019
    Northern Maine
    150
    Nice trikes guys. So I need suspension but also have to keep the airbox. Or fab up a solution. I trail ride a lot in the summer and deep water is part of the fun for me. The machine I want to modify is a 200s I put together from parts. The frame is damaged a little in the rear from a previous owners wreck, but as long as decent chain tension is maintained it works fine. We have put quite a few miles on our 3 ATCs in the last few years. But my back is a wreck. Suspension would help a little but definitely won't alleviate the problem. After a day of riding I need a week to recover. Winter is here. Perfect time to fab up a suspension setup. Any suggestions! Tips, tricks?
    Take care and thanks
    Corey
    az
    1,949
    if you need pics or measurements let me know, the latest frame might not get worked on for awhile if ever. I don't have plastics or a seat for it. I do have plastics, seat and tank for 1 of the 200s trikes so the 200s will get put back together next. not sure what's going to happen with the 185s trikes. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    Dec 2021
    Glendale, AZ
    29
    I had a full suspension 185s back in the late 80's. PK kit - It did pretty well but I remember having continual issues with the chain tensioner. Still, cool bike. I am in Phx, btw. Gotta love the dry bikes for sale out here.
    Feb 2020
    US
    57
    Quote Originally Posted by flightofphx View Post
    Hey buddy. Can't find your original message specific to the question on the 200x carb on my 185s.
    The carb bolts on with no mods. It's a stock engine with a cobra pipe and oem airbox with a k&n filter. Ended up running a 100 main and it's on the rich side, but runs well. Not a massive power upgrade, but I'm not a great carb tuner. New fender decals from ddr slapp.
    Sent from my SM-G960U using Tapatalk
    Dec 2021
    Glendale, AZ
    29
    Quote Originally Posted by agedatc View Post
    Thanks! Glad it is a direct bolt-on. Very cool 185s, btw. I am wondering if anyone still makes rear suspension kits for 185s/200s. Are you still running 22inch rear tires?
  15. #30
    Feb 2020
    US
    57
    I've got 20x11x9s on the back. Went up to a 12 on the front sprocket to account for the smaller diameter
