Thread: Id on an atc.
    Sep 2018
    Utah near Fillmore
    4
    Question Id on an atc.
    I have looked around the forum and someone put up a list of model number years but I couldn't find my engines number on it TB05E-5333140 I haven't been able to figure out what it is. Also this thing is an abomination. it is a honda atc something in a 1984 honda xr200r frame which makes identifying the motor difficult. It doesn't have reverse. It also has an automatic clutch.
    6,726
    Got a picture of each side of the motor ? Their are slight changes between years and will help identifying what you have .
    The base of the cylinder will have the cc size either 192 or 180 . Is it an up shift or down shift transmission ?
    Sep 2018
    Utah near Fillmore
    4
    Pulling the shift lever up shifts down and shifting down goes up. Ill also check the engine for cc tomorrow it is dark and cold outside.
    6,726
    Ok so it’s a down shifting motor that means it was made from 1980-84 .
    Monroe MI
    5,787
