Results 1 to 15 of 21
Thread: 200es
    Aug 2020
    florida
    58
    200es
    Got a 84 200es that had water in the cylinder from guy leaving the spark plug out like a dummy and will need a new top end, rest of bike is in great shape. My ? is will a 250 top end fit on the 200es?
    Nov 2019
    Florida
    1,044
    Not to my knowledge, have your cylinder bored out and get a matching piston, but it wont be 250cc.
    mrc_builds on YouTube Channel
    My Addiction
    85 200m "Tallahassee"
    84 200x "SouthPort"
    84 200x "Van Halen"
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "The Money Pit"
    85 350x Code Red
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    Jul 2019
    Shelton
    96
    I would just bore it, new piston, and take the valves out to make sure they are free in the guides and the seats are not rusty and pitted or get the head freshened up at a machine shop.
    2,535
    MrCondid is right. These are completely different engines and the top ends won't swap.
    az
    1,949
    are you sure there is no water in the crankcase? jim
    81 185s
    82 185s with 85 200s motor
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    projects coming along
    85 200s
    1982? 185s
    Aug 2020
    florida
    58
    No water in crankcase
    6,727
    The cheap route is to buy one if these kits , you’ll have to make a cover /cap for the different style chain tensioner but otherwise it’s a bolt on kit .
    https://www.ebay.com/itm/15462273062...3ABFBM0MqY6Zdf
    Aug 2020
    florida
    58
    Are you talking about the cam chain guides?
    2,535
    If you're referring to post 3#, then it's talking about the valve guides.
    Aug 2020
    florida
    58
    No Post #7 about making caps/cover for tensioner
    6,727
    The aftermarket cylinder is universal, it needs a cover over the hole in the side of the cylinder .
    Their are a few threads on this site were these cylinders were used .
    Aug 2020
    florida
    58
    Found it, thanks everyone.
    Aug 2020
    florida
    58
    Update, i got one of the ebay cylinder/piston kits and this is what i found.
    Bore is 63.5mm compaired to the oem that is 65.00mm
    New piston does not come to top of cylinder, is down 4.80mm down in bore on the new cylinder.
    So this tells me it will be lower compression and less hp from factory.
    How much difference will this make?
    az
    1,949
    if its that far in the hole, I'd just look for a used cylinder, correct me if I'm wrong but a 200s cylinder might swap. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    6,727
    I have rebuilt a few motors using these kits as well as others on this forum, yes the piston is a little lower by about 4mm but their was no noticeable difference in power .
    Also its a domed piston were the factory piston is dished so the compression is equal if not more than the factory piston .
    Quote Originally Posted by haroldpo6 View Post
