Got a 84 200es that had water in the cylinder from guy leaving the spark plug out like a dummy and will need a new top end, rest of bike is in great shape. My ? is will a 250 top end fit on the 200es?
Not to my knowledge, have your cylinder bored out and get a matching piston, but it wont be 250cc.
mrc_builds on YouTube Channel
My Addiction
85 200m "Tallahassee"
84 200x "SouthPort"
84 200x "Van Halen"
84 250r "lucky"
85 250sx "Enterprise"
85 350x "The Money Pit"
85 350x Code Red
86 250r "Unicorn"
86 trx250r
88 Lt250r Suzuki
I would just bore it, new piston, and take the valves out to make sure they are free in the guides and the seats are not rusty and pitted or get the head freshened up at a machine shop.
MrCondid is right. These are completely different engines and the top ends won't swap.
are you sure there is no water in the crankcase? jim
81 185s
82 185s with 85 200s motor
suspended 185s
85 atc70
1984 200s
85 350x 3rd owner
and a 72 ct70
projects coming along
85 200s
81 suspended 185s (can't believe I came across 2)
1982? 185s
No water in crankcase
The cheap route is to buy one if these kits , you’ll have to make a cover /cap for the different style chain tensioner but otherwise it’s a bolt on kit .
https://www.ebay.com/itm/15462273062...3ABFBM0MqY6Zdf
Are you talking about the cam chain guides?
If you're referring to post 3#, then it's talking about the valve guides.
No Post #7 about making caps/cover for tensioner
The aftermarket cylinder is universal, it needs a cover over the hole in the side of the cylinder .
Their are a few threads on this site were these cylinders were used .
Found it, thanks everyone.
Update, i got one of the ebay cylinder/piston kits and this is what i found.
Bore is 63.5mm compaired to the oem that is 65.00mm
New piston does not come to top of cylinder, is down 4.80mm down in bore on the new cylinder.
So this tells me it will be lower compression and less hp from factory.
How much difference will this make?
if its that far in the hole, I'd just look for a used cylinder, correct me if I'm wrong but a 200s cylinder might swap. jim
81 185s
suspended 185s
85 atc70
1984 200s
85 350x 3rd owner
and a 72 ct70
85 200s
1982? 185s
I have rebuilt a few motors using these kits as well as others on this forum, yes the piston is a little lower by about 4mm but their was no noticeable difference in power .
Also its a domed piston were the factory piston is dished so the compression is equal if not more than the factory piston .
