Results 1 to 10 of 10
Thread: Honda 85 Big Red rear shock question
    Nov 2021
    New Brunswick, Canada
    7
    Hi everyone,
    I recently put new rear tires on my 250ES (Bear Claws are awesome!). They're a little bigger than what was on there before, so they rub up on my plastics a little bit in rough terrain. I considered making a lift, but then though why not swap the rear shock for one that's an inch or two longer? (i think stock is 14.5" eye to eye) Has anyone done this, or have advice about it?
    I've seen people near me parting out trx300's/350's. Saw a Scrambler too. Would any of those fit, and if so would they be too stiff?
    6,725
    The trx300 fourtrax is 14.5 so it’s the same .
    Not sure on the rancher
    Nov 2021
    7
    Thanks for the info
    I think the Scrambler shock is 16". Anyone have any thoughts on that one?
    Or suggestions about ones you know would fit?
    The issue will the the width of the eyes the big red has narrow mounts. There is acouple of there threads on here about different shocks and what fits and don’t fit.
    Aug 2019
    Texas
    7
    I have the exact setup on mine. I had a trx250x shock on mine and it felt like a hardtail. I currently have a trx450es front shock on mine. What size are your tires? Mine are 26x12x12
    Nov 2021
    7
    They're 25x12.5x9 on paper, but the treads stick out further than that.
    How are you liking the 450 front shock? Is it longer than 14.5?
    Aug 2019
    Texas
    7
    I seems to be about the stock height, i will measure it later today to verify.
    “Pb blaster, blow torch, and a liberal amount of french will unstuck any stuck bolt.”
    69 ct90
    71 ct70
    74 cb350
    76 xl100 (12v mod)
    84 xl125 (xl125s motor swap)
    85 250es
    85 250sx
    86 ct110
    86 trx125
    98 tw200
    03 ttr125 (heavily modded)
    03 yz85
    03 xr70 (heavily modded)
    92 dodge w250 (daily)
    https://www.instagram.com/brycedamemechanic/
    Aug 2019
    Texas
    7
    Shock is 14.5 eye to eye. Lifting the rear an inch or two is extremely easy. All you need is some angle iron.
    69 ct90
    71 ct70
    74 cb350
    76 xl100 (12v mod)
    85 250es
    85 250sx
    86 ct110
    86 trx125
    98 tw200
    03 yz85
    Nov 2021
    7
    Yeah, that's what I was thinking of doing in the first place, but got distracted by the prospect of a smoother ride...
    I think you sold me. I'll start by making a lift and revisit the shock-swap later.
    Thanks a bunch!
    Aug 2019
    Texas
    7
    No problem!
    69 ct90
    71 ct70
    74 cb350
    76 xl100 (12v mod)
    85 250es
    85 250sx
    86 ct110
    86 trx125
    98 tw200
    03 yz85
