Thread: 1984 ATC 250R - Wet Side Crank Seal
    May 2003
    Houston, Texas
    2,409
    Hey Guys,
    I've got a wet side crank seal oil leak on my '84 R.
    Can the crank case cover be taken off with the engine in the frame? Look tight near the front.
    Need to get to the the wet side seals.
    Thanks! Click image for larger version.
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    6,811
    Yes the clutch cover can be removed without removing the motor .
    May 2003
    Houston, Texas
    2,409
    Thanks...can you get to the seal behind the counter balancer?
    Dirtbikes:
    1988 Yamaha DT
    6,811
    Yes the crank seal can be replaced fairly easy .
    Carthage NY 250r rules
    2,355
    No you cant remove the clutch cover on the 81-84 250r with the motor in the frame.The front motor mount bolt goes through the cover.
    250r rules
