Results 1 to 15 of 19
Thread: its that time again, ATC70 BUILD COMING.
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,237
    this is the place to start a new build, to much gets lost on the pages! so lets have a little fun again, its been a while since i have used the fourms so be kind. i now have grandsons so we are building a suspension 70 for him. since the world has changed a great deal in the last 10 years this might take a little longer, not sure about picture attaching either . i like big pictures so i will try to figure it out . first off no idea on color yet as i am not picking it out. so lets see what we can do about pictures first. Click image for larger version.
    KASEY's Avatar
    4,237
    WTF???? IS THERE A SIZE LIMIT ON ATTACHED PICTS? tried a few none work.
    6,726
    Not sure either , I haven’t been able to post any pictures for months now .
    Congrats on the grand kids !
    Are you starting from scratch or do you have an A+ frame ?
    KASEY's Avatar
    4,237
    i have an A+ frame wow it let me load it.Click image for larger version.
    KASEY's Avatar
    4,237
    here is how far from basic i am starting,,,,, can you figure out what this is going to be?
    KASEY's Avatar
    4,237
    ok i think i figured this out.... here is where i am starting on the motor. boring the cases to do a big bore non stroker,
    Mexico
    9,010
    Prettier???
    It sucks to get old
    KASEY's Avatar
    4,237
    the frame i am starting with is in real bad shape. i started by cutting off all the brackets and had them all remade. probably why this is going to take a little longer, want everything just right, i made a few sets so i have spares just in case.
    KASEY's Avatar
    4,237
    Prettier???
    lol you got that right!!!!
    KASEY's Avatar
    4,237
    start with the bottom mounts, once positioned proper i will do the top ones too a lot of this work is already done so i am searching for picts from a moth or 2 ago so you can see what it takes to bring one back. also sent a ton of stuff out to replate , like clean hardware to make a big difference in detail and its all honda OEM too.
    KASEY's Avatar
    4,237
    over the years i have not stopped building, i have just got caught up in the rush and have not taken the time to share builds like i use to, here are a few of them,
ID:	268607Click image for larger version.
ID:	268608Click image for larger version.
ID:	268609Click image for larger version.
ID:	268610Click image for larger version.
    KASEY's Avatar
    4,237
    ok so here is that ugly plate i started with, i found a set of junior dragster rear hubs s\from lonestar, so i needed a matching front hub, i turned it out to the proper size to match the 5 lug wheels, turned a stock hub flange off and mounted the new flange on it, i cut it out out and drilled it to match, since i dont have a color combo yet i am sure they will get painted some color.
ID:	268612Click image for larger version.
ID:	268613Click image for larger version.
ID:	268614Click image for larger version.
ID:	268615Click image for larger version.
ID:	268616Click image for larger version.
ID:	268617Click image for larger version.
ID:	268618Click image for larger version.
    KASEY's Avatar
    4,237
    since this is for the kids....... its true. i had no need to beef up the clutch or the transmission so i am using a stock bottom end. went with an 85 so they get use to up shifting , i bought a 54 mm piston kit from dratv and a short cylinder from tbolt. nobody makes a kit . so it will be a short stroke 95 cc motor. it will rev quick and low end grunt, i am using a newer late model xr70 head since the cam runs on bearings not in the aluminum, got a little more than stock lift but not much. all i had to do is clearance the oil pump shaft and bore the cases , the motor looks stock except the cylinder is aluminum , going to build the manifold so i can keep a 20mm carb under the tank like stock too.
ID:	268620Click image for larger version.
ID:	268621Click image for larger version.
ID:	268622Click image for larger version.
ID:	268623Click image for larger version.
ID:	268624Click image for larger version.
    Buffalo, NY
    1,991
    I love watching your builds Richard, thanks for sharing
    KASEY's Avatar
    4,237
    had a little time to kill so i decided to do away with the crush drive and go solid,, besides i couldn't get the sprocket size i was looking for , so here it is. old and new.
