Results 1 to 9 of 9
Thread: Slip on muffler leaking
    Apr 2019
    Massachusetts
    58
    So the backstory is I got one of those factory replacement mufflers for my 200es from Dennis Kirk, and it's supposed to be slip on but has never sealed well at all to the original front pipe. I first tried using some aluminum foil to seal it, and that blew out almost immediately. Then I tried a sheet of lead, and that worked amazingly well, but only lasted for a couple months before it blew out too. I can't really find anything else that's meant for this, so I was wondering if anyone had any suggestions. There's only a small gap, wrapping aluminum foil 2 or 3 times around fills it, but it's big enough that I can feel exhaust gasses coming out, and it lets air in and pops really loudly when I let off the gas (it's tuned fine, it didn't do that when I had it sealed up briefly)
    9,012
    Brass shim stock might do it. Is it something you could cut some slots in and then clamp?
    It sucks to get old
    az
    1,949
    they sell muffler gasket sealer, it's like rtv, comes in a tube made for exhaust. auto parts stores carry it. jim
    81 185s
    82 185s with 85 200s motor
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    projects coming along
    85 200s
    1982? 185s
    Apr 2019
    Massachusetts
    58
    That's what I was doing with the lead and aluminum, maybe brass would hold up better? I can't cut slots and clamp it cause it's such thick metal it wouldn't really clamp at all.
    Apr 2019
    Massachusetts
    58
    Quote Originally Posted by Jim mac View Post
    Cool, I'll check that out. Do you think it would be able to plug a 1/16" gap or even a bit bigger?
    2,210
    Permatex 80335 Muffler and Tailpipe Sealer
    https://www.amazon.com/Permatex-8033.../dp/B000BOAZM8
    Typical auto parts stores usually have some on the shelf.
    You could try the Ultra Copper if the above isn't available. It's not as heat resistant though.
    Apr 2019
    Massachusetts
    58
    Awesome, thanks. I'll give that a shot and update on here
    Scootertrash's Avatar
    In the sticks
    4,628
    How about some thin metal tubing?
    Small exhaust pipe adapter/reducer? Outside of head pipe diameter to outside of muffler pipe diameter?
    That goop/paste stuff sux, gets hard and dries out.
    What is the O.D of the head pipe and the O.D. of the muffler pipe? pics?
    Apr 2019
    Massachusetts
    58
    Really hard to get a good pic but I'll measure the diameters when I get a chance. It would have to be REALLY thin metal, only 2 or 3 layers of aluminum foil wrapped around took up the space
