Thread: Timing chain trouble on a tare down
    Feb 2022
    Shakopee MN
    42
    I'm trying to do a tare down of a locked up 85 250es motor I got on a parts bike. I've never done this before, so forgive me if I'm missing something obvious. I need to get the timing chain off and I can't seem to do it. I took the tensioner off, but there's not enough slack to get it off. I also wasn't lucky enough to have the sprocket be in a position where both the retaining bolts are accessible. I was really hoping to do a top end rebuild only on this motor as I'm guessing it's locked up from sitting outside, but the only way forward I can see is to break the chain.
    Anyone have anything else I could try? Also, I watched a video of a 250sx motor tare down, that guy only had to remove the tensioner to get enough slack, is my motor weird or something?
    Feb 2022
    Shakopee MN
    42
    I've been trying to use the search to find out more on what I can do here, but I'm not very good at using it yet.
    So far I've found a post that says while installing a new chain you have the cam sprocket unbolted to have enough slack in the chain. If my chain is not stretched out, this would explain why I don't have enough slack to take it off. Unfortunately, since I can't access both the sprocket bolts, and have no way of getting the piston to move, it looks like I'll be having to buy a cam chain breaker.
    Sound like I'm on the right track here or is there something else I could try?
    6,727
    Did you try turning the crankshaft back and forth at the flywheel ?
    I’ve run into this situation several times , the last one I was able to pick up on the back side of the cam and put it at an angle just enough to pry the chain off without hurting anything .
    Feb 2022
    Shakopee MN
    42
    I haven't tried that, but it sounds worth trying. I'm not too hopeful though, when I pulled the spark plug I could see the piston is rusty, I'm guessing this thing is locked up hard.
    6,727
    Put plenty of penetrating fluid down the plug hole to try and free up the piston
    Feb 2022
    Shakopee MN
    42
    Duplicated this post and got more traction on it here:
    http://www.3wheelerworld.com/showthr...e-on-tare-down
