Thread: cant get engine to turn over 83 200x
    Feb 2022
    Chickasha,Oklahoma
    18
    The top end was tore down and sat in pieces for several years. The piston is down in the bottem end, and I cant get the motor to turn over. ( I'm changing the piston).
    207wheelin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2019
    Northern Maine
    150
    How far into the teardown are you? Have you soaked the piston and cylinder with penetrating oil?
    Any pics?
    Feb 2022
    Chickasha,Oklahoma
    18
    The whole top end is apart. Ill try soaking it in oil, and maybe get some pics.
    Mar 2019
    Northern Maine
    150
    Once you get some penetrating oil in there and let it soak you can get a piece of hardwood and start tapping. This should help even if the piston is at the exact bottom of its stroke by helping the oil to penetrate. It can help to put a wrench on the crank and add some tension while tapping. Just do this gently as you dont want to damage the crank bolt. Just be patient and you'll get it! Any questions or if you make any progress let us know.
    Take care
    Corey
    Feb 2022
    Chickasha,Oklahoma
    18
    thx man I got it, just was doing it wrong
