Results 1 to 8 of 8
Thread: Lighting coil?
    Feb 2022
    Baltimore
    23
    Lighting coil?
    Hello all, I'm rebuilding a 1983 YTM200K. I bought this trike for the seat pan and the plastics for my YTM200ER. The engine was there but the head bolts were gone so I took it apart and everything looked fine. The head exhaust mounting holes were trashed so I found a 225DX junker with a good head and other good parts. I honed the cylinder and put a new set of rings and the 225 head on it and it runs great, clutch is good and has all 5 gears. I moved on to check and see if the lighting coil still worked, this is where I may have messed up. I took the 225 tail light and put it on the 200K not realizing it uses a different bulb. The light worked though was very bright, when I revved up the throttle it got really bright then quit. Could the wrong bulb have fried my lighting coil?
    Thanks
    1982 YT175
    1983 YTM200K
    1984 YTM225DX
    1985 YTM200ER
    207wheelin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2019
    Northern Maine
    150
    Can you test the bulb and see if it got blown?
    Apr 2014
    Edmond, KS
    2,531
    I would agree with 207. I think it would be more likely that the bulb blew out.
    Feb 2022
    Baltimore
    23
    I put the tester on the lighting output wire and got 12 to 20 v , but on the AC setting, got nothing on the DC setting. Does this trike use an AC bulb ?
    Thanks
    1982 YT175
    1983 YTM200K
    1984 YTM225DX
    1985 YTM200ER
    Feb 2022
    Baltimore
    23
    Think I figured it out, I was told it is an AC bulb. I also read another thread here that you cannot run just the taillight or it will burnout, the current needs to be distributed to both bulbs. Is this right?
    1982 YT175
    1983 YTM200K
    1984 YTM225DX
    1985 YTM200ER
    Mar 2019
    Northern Maine
    150
    I believe that is correct. I know on my Hondas that's how it works.
    Take care
    207
    Feb 2022
    Baltimore
    23
    Got a new headlight bulb and all works great.
    1982 YT175
    1983 YTM200K
    1984 YTM225DX
    1985 YTM200ER
    Mar 2019
    Northern Maine
    150
    Awesome man!
    Take care
    Corey
