Results 1 to 7 of 7
Thread: Can’t find std rings for 185s any alternatives wiseco/XL185??
    Wisconsin
    118
    I have a 185s it ran good but smoked bad and had 50 pounds of compression took it all apart the cylinder and piston looked great honed the cylinder out and started looking for std rings but cannot find any for a 185s found them for a 200s but not sure if the bore is the same? I thought either trying wiseco or rings from a XL185?
    83 Honda 250r
    85 Honda 70
    83 Honda 185s
    85 Yamaha Tri-Z (restoring)
    83 Honda 70
    79 Honda 70
    74 Honda Z50
    78 Harley Davidson Golf Cart w/Big Red Engine!!!
    6,727
    Not a lot of options left for a std 63mm bore anymore .
    The wiseco rings are different , won’t fit a factory piston .
    I’ve used this kit in the past and it worked great .
    https://www.ebay.com/itm/39347953018...QAAOSwJ2hhBOpw
    az
    1,949
    I've got a couple smoking 185s motors in the shed and bought 2 of those kits too. jim
    81 185s
    82 185s with 85 200s motor
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    projects coming along
    85 200s
    81 suspended 185s (can't believe I came across 2)
    1982? 185s
    Jul 2021
    Anthem Arizona
    42
    Just buy a wiseco 66mm 10.25:1 piston and bore the cylinder, you will kick yourself for not doing it sooner.
    207wheelin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2019
    Northern Maine
    150
    I only have 1 185 engine and it runs great without smoking but at that price I bought a kit to put in my parts stash!
    Thanks for sharing that link!
    Take care
    207
    I may have a set, I've got a box with old Cycle Craft, Rocky and Sudco rings and I'm positive there are some 185 rings in there.
    63mm??
    These are all marked ATC185. Ricky's say standard and no name set does as well. There are part numbers on the boxes, I've researched them before and sold a few dozen that were easy to identify quickly...
    I've had these for a long time and they were already old when I bought them, I imagine the "no name" rings are also Japan because all of these were 80s brands...
    Sent from my SM-A426U using Tapatalk
