Thread: how to figure which carb is what?
    az
    1,949
    over the years I've bought projects missing carbs, having china carbs, stock carbs etc. if I have a few stock type 185s or 200s carbs in a box, how do I figure what carb goes to which trike? I went to 223cycles and the rebuild kits for the 185s and 200s has different part numbers. thanks. jim
    81 185s
    82 185s with 85 200s motor
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    projects coming along
    85 200s
    81 suspended 185s (can't believe I came across 2)
    1982? 185s
    6,722
    The big difference in the carburetors are the float valves , their are two different styles , one has the metal clip and the other just slides in . A 200s carburetor should use the metal clip style float valve .
    az
    1,949
    thanks, when I get a chance I'll pull some float bowls to look. jim
    81 185s
    suspended 185s
    85 atc70
    1984 200s
    85 350x 3rd owner
    and a 72 ct70
    85 200s
    1982? 185s
    207wheelin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2019
    Northern Maine
    150
    I have a box of old carbs too. Some of them have different size slides. Any idea what models used a small slide carb?
    6,722
    All the Atc 200 / 185 models are 22mm carburetors except for the 200x it’s a 24mm and the xr200 is 26mm .
    If your talking non OEM carburetors then who knows lol .
    Mar 2019
    Northern Maine
    150
    That's good information to have. Thanks Shortline.
    Time to look over what I've got and rebuild one to replace a leaky China carb on my daughters bike.
    Take care
    Corey
