I guess I watch too many of mrcbuilds and I must be board. so there's a roteka 50 quad for 60 bucks. even came with 3 extra brand new tires.
throttle is stuck, key is broke off, hooked up my battery charger sprayed some carb cleaner in the carb and it started right up. throttle popped loose, tried gas in the carb but the needle must be stuck because it won't run on the carb. So I'll clean the carb and see what happens. jim
