Got a 88 TRX300FW last week, started digging into it's issues, the worst one is how it's running.
Pulled the carb, cleaned it and I'm no stranger to cleaning carbs, it's spic and span clean, put a carb kit in all new parts, got it back on and the same issue. It will start just fine but it's running super rich, like starts to burn your eyes running it in the garage with the doors open rich. Mixture screw doesn't seem to affect it, cranking out the idle stop all the way don't change it, if you try and tap the throttle it just dies.
My first thought is of course carb issues obviously but I can't narrow down what it is. The choke plunger wasn't stuck and I put a new seal on the plunger but it acts like the choke is always on, and turning the choke from off to on and vice versa don't seem to make any difference. I pulled the carb again, checked everything again, it's super clean and fresh gas no issues.
It's been about fifteen years since I worked on a carb with the choke slider setup and those were 250ES's but this carb is very similar. I ordered a new choke plunger set, mainly cause after tearing down the carb and testing again five times I was at my wits end and don't know what else to do.
What would cause this thing to run this rich? Jets all stock sizes, carb has been cleaned five times and you couldn't find dirt or blockages if you tried. I'm still thinking it's a choke issue since turning it on and off don't make any change but I can't figure out what that issue is?
Suggestions?
Got it on a trade and fixing it up, pulled the front end apart to replace seals on the front diff and both cv axles today, got the leaks fixed and everything else is good other then brakes which I'm waiting on parts for, just can't get it blessed thing running right.
The previous owner punted it because he had the same issue despite cleaning the carb twice. Guessing we both missing the same thing but no idea what that would be.
ned them with this awful flat gray, maybe just primer, looks like crap.
