Hey guys I need some advice.
My 85 350x has a problem (has always had) with either the kicker assembly / bearings, the idle gear or bearings or the transmission.
I have stated before it is hard to kick, now that it has a new top end it's even harder.
Here is the set up and what it does.
No plug installed, in neutral, decomp working = extremely hard to kick over
No plug installed, in gear, decomp working = is easy to kick over and the bike moves forward like you would expect.
No strange noises or clunks, I feel something is in a bind, and when the trans is in gear whatever is in a bind can no longer bind and is easy to kick over. I have ruled out the needle bearing on the kicker, just
due to that pressure point is the same whether in gear or not, so that leads me to a trans/syncro/shifter issue?
The only thing I haven't tried yet is to put it in gear and pull in the clutch and see how hard it is to kick over.
Thanks for your help.
MrC.
