Looking for some suggestions on my black smoke at idle.
Bought a 250SX late last year and rebuilt the carb on it. Started with just a cleaning, then did all the jets.
This is the list of stuff I have done to the carb:
- Tear down including removal of jets, ultrasonic cleaning for 8 hours+ (rotated during this period). Blow through all ports. Reassembled with original jets and new Honda float needle, Honda bowl gasket, Honda pilot screw oring.
- Cleaned/polished float needle seat (was overflowing from overflow before doing this)
- Tear down again, installed Shindy jet kit 03-028. (trying to fix black smoke at idle)
- Moose Racing Choke Plunger Kit 46-1014 (I only used the seal, the plunger did not match the original) (trying to fix black smoke at idle) (choke moves freely)
- Adjusted pilot screw. It makes a difference in running, but does not seem to affect the black smoke.
Ran it some more today, and it is still puffing black smoke at idle. It runs well otherwise, maybe slightly less power than I remember. But well.
If it sets idling long enough it will stall. It restarts without much trouble but will puff more black smoke.
I have been thinking maybe float, but wanted to get another opinion. I see many similar posts (86-87 250sx, 250es, 350x) with black smoke at idle, but no resolution.
Today I put a clear hose on the drain port of the bowl, here is the level indicated by the hose. Seems high?
