Results 1 to 12 of 12
Thread: Difficult to cold start 350X
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    300
    Trying to help a friend with his 1985 350X. It does not like to start when cold. It will start and idle for a few seconds and then die. You must repeat this process until it eventually warms up enough to run. Different pilot jets have been tried all yielding the same results. It is basically stock with a 400ex header and aftermarket exhaust. Any advice?
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Aug 2016
    East of Worcester ma
    1,328
    Tight valves would be my guess. Might be time to check them. low compression?
    shep
    Soutwestern PA
    2,040
    ^^^^ I'm with Shep. When they don't start, it's the valves a remarkably high % of the time.
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    300
    He says the valves have been adjusted and rechecked.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    300
    I ended up buying this 350X from my friend. It has an incredible lean pop on decell. We tried multiple pilot and main jets with not much change in the lean popping. I believe there is something going on with the float valve that is causing the float to stick, hang up or just move slower than it should. I have been able to start it cold after priming the carb.
    The engine seems to run good otherwise and seems quiet (no ticking or slapping). It sure is a blast to ride through my tight woods trails.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    6,728
    Are you sure their are no exhaust leaks ? That will also cause the deacceleration back firing .
    As for the carburetor the easy solution it to just buy a new OEM 400ex carburetor .
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    300
    I will check for an exhaust leak. I have thought about using a 400ex carb. is there an intake boot that makes this easy or do you have to stretch or modify the stock 350x boots?
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Nov 2019
    Florida
    1,044
    Hey Footy,
    I will second the 400ex OE carb. Like others have said valves contribute to a lot of carb problems.
    I will tell you I had a crack in my intake boot, between the carb and head, they tend to dry out and split.
    Also if you put the 400ex carb on. I recommend using grease on the inside of the intake and a heat gun
    the 400ex carb is bigger than OE.
    Great upgrade!
    mrc_builds on YouTube Channel
    My Addiction
    85 200m "Tallahassee"
    84 200x "SouthPort"
    84 200x "Van Halen"
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "The Money Pit"
    85 350x Code Red
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    300
    Quote Originally Posted by MrConcdid View Post
    Hey Footy,
    Great upgrade!
    Thanks for the tip. Can you still buy the intake boot new?
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Nov 2019
    Florida
    1,044
    I bought a good used one. you can find them on ebay and also check out the FB group "King of the Hill" ran by Lou Bothello, he has a ton of 350x parts.
    I believe the intake for the 300d is the same.
    My Addiction
    84 200x "SouthPort"
    84 200x "Van Halen"
    84 250r "lucky"
    85 350x Code Red
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    300
    I am going to assume you are referring to the TRX350D 1986 or 87?
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Nov 2019
    Florida
    1,044
    Quote Originally Posted by Footy View Post
    Oops yes 350D.
    My Addiction
    84 200x "SouthPort"
    84 200x "Van Halen"
    84 250r "lucky"
    85 350x Code Red
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
