Results 1 to 3 of 3
Thread: Rear sprocket cross reference.
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    299
    I am trying to figure out if the ATC350X rear sprocket is the same as one of the more popular TRX models, say the 300 or 400EX or 450R. My 350X does not have a swingarm skid plate. I am thinking about using one of the sprocket rings (like BCC sells) but I am not sure which one would fit as these are not specifically offered for ATC models. My thinking is that if the 350X shares the rear sprocket mounting with another TRX then that sprocket guard would probably fit the ATC.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Jun 2013
    Oceanside, CA.
    610
    Which year model 350x do you have? '85 use a thru bolt and nut where the '86 uses a countersunk bolt head and nut.
    "HJ" Click image for larger version.
    ’84 YT60
    ’89 TRX250R (stock )
    ’90 LT500 Quadzilla
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    299
    Quote Originally Posted by HairyJR View Post
    Excellent question. From what I can see this 350X is a blend of both years. I do see nuts holding the rear sprocket onto the sprocket hub so I will have to guess that that part is from a 1985. This might make using the ring style sprocket guard tricky or impossible. I need to compare this setup more closely to my TRX450R.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
