Thread: '86 250sx won't shift into any gear when on or off
    Jul 2022
    Picton, Ontario
    I recently picked up a '86 250sx. Got it cheap. Currently it will not shift into any gear while on or off. I took the side cover off and the shift shaft looks good. Couldn't see anything obvious. About to start into the transmission but had some time so I figured I'd check in for any advice. Have the other cover off as well and clutch looks good ( although I really don't believe it to be a clutch issue ) and can't see anything obvious.
    gimmeamidget is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    utah
    436
    its a common problem on the 250sx and 250es. I dont recall the part but it comes loose or shears off and causes the same shifting issue you mention. Try searching big red shifting isues and there are a few threads that show the parts diagram and the part that fails.
    Jun 2014
    utah
    436
    seems like its under the left cover if my recollection is correct
    Jun 2014
    utah
    436
    Look at part #21 on the diagram for the left cover. Part number you are looking for is 24652-HA0-000. hope this helps.
    Jun 2014
    utah
    436
    Feb 2023
    Lodi
    7
    I'm having a similar issue. I just picked up a 1985 250SX and it has some problems. It's having a very difficult time shifting at all. I can maybe do one down and 1 up and that's it. It didnt want to shift into anything else. The shift shaft looks really good and nothing is broken on the left side under the crank case cover. I took the right side off and obviously when I took the shift shaft off something fell out on the right side so I'm peicing that back together and the clutch adjustment bolt is completely seized in the cover. I don't want to break anything, but any ideas on how to get that damn thing out??
