Results 1 to 9 of 9
Thread: 1984 atc 200x ?
    Aug 2020
    florida
    63
    1984 atc 200x ?
    I'm looking at a 84 200x that the seller says lost all gears, but still runs good. What all could this be?. I have rebuilt several 200, 200es before, but nothing with a clutch, or kick start.
    6,811
    Possibly burnt up clutch or stripped out sprocket shaft .
    Aug 2020
    florida
    63
    Thanks, he said 3rd gear was acting up and his kid was riding shifting from 2nd to 4th and then nothing. I'll tear into when it cools off some in nw florida.
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    437
    Sounds like a bad shifting fork. Possibly a broken gear as well.
    TRX450ER
    ATC250SX
    ATC350X
    ATC250ES
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Aug 2020
    florida
    63
    I starting to order parts i know i will need when i tear the engine down and would like to know what complete gasket set is everybody using right now. I'll wait on the bearings until i get into it. I've used vesrah sets on 200es, 200, etc without leaks before, but is been a while.
    Williamstown PA
    5,825
    200X gears were weak, it needs a full rebuild. kicker gears always sucked on them. They need back cut a machined shim added and a new kicker spring. I have done many. I will not another one. Bad design, tired 40 year old motors...No thanks. A different motor is better swap like CRF230...
    Nov 2019
    Florida
    1,048
    Is it located in Blountstown Florida?
    I just looked at one with the same description, real interesting seller too.
    I rode it 2 months ago, it needs everything, it was slipping bad then and smoking a carton.
    He wanted 3k and said he had the title, lol the title didnt match the trike. He also said he had a leather tank cover, But I never saw it.
    I have a 200x and a few others if your looking to buy a trike. PM me if your interested.
    MrC
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    85 350x "Yard Sale" Flat Tracker
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
    Aug 2020
    florida
    63
    Sounds like the same one, he's dropped the price way down.
    PM sent
    Aug 2020
    florida
    63
    Update, Top (R) shift fork broke in half, reason why it whould not shift, 3rd gear chewed up. This engine has been thru alot. I found all the parts to fix it on fleabay
